MSJKU11
Just found out that I have 3.73 gearing when I thought I had 4.56. I pulled off the differential cover originally and tried to count the teeth but I guess I didn't do it correctly. I found my original spec sheet(why didn't I do this first) and counted tire rotations to DS turns and come out to 3.73 also. I'm currently running a 2.5 lift with 35s and probably won't go any higher. I know this has probably been talked about a lot but who has a similar setup and which gearing did you go with and why? I will be modding for trails in the future that is around AR and GA.
