Jeepfan30
If I was gonna buy a kit what would be a good complete one?
I believe you want the OTC 7894 adapter. Use that with the kit you rent from auto parts store.
8 months. Rubicon 7 times, Hellhole 3 times and some aggressive snow wheeling. Running 37" Nitto trail grapplers and 3.5" RK X factor.OP, how long did you have the Synergy ball joints in before they died on you? I read before that they were being raved about and I have a set on my workbench that I plan to install this weekend.
Thanks.I believe you want the OTC 7894 adapter. Use that with the kit you rent from auto parts store.
If I rent the Autozone one I will just need the adapter Right?I have the Matco BPS400. You should be able to find them for under $200.. probably under $150 if your patient.
Well, ball joints are gone again. These are Synergy. Need some advice on which ones to get, my buddy Has Prosteer and swears by them. What say you? My goal is not a lifetime set as from what I've read and prove I've talked to that might be a pipe dream. Prosteer can be rebuilt on the vehicle. Thanks.
You and me both.Went through three sets of OEM in 60K miles (including the set that was there from the factory). I think my Jeep was one of the first non-test JK to install the Synergy balljoints; literally installed them the day they hit the market. They lasted 40K miles. Got sick of replacing balljoints, so Installed ProSteers.
Wish I had just done the ProSteers from the beginning.
Yessir. Just make sure it has the Jeep/Mopar adapters.If I rent the Autozone one I will just need the adapter Right?
TyYessir. Just make sure it has the Jeep/Mopar adapters.
