*BODY LIFT* Jeep JK - 2 doors - Manual... -_-“
BenJKWrangler15
I see dirt roads and a mud hole. But aside from that...if you’re trying to clear 37s a body lift is not the proper method. To clear 37s you need at least 3 inches of lift and cut stock fenders or tube fenders. I wouldn’t even waste my time with a body lift and I would go straight for cutting the stock fenders to clear up that extra room
Thanks for the input
benatc1
Cut the fenders and 2” rancho lift, cheap, easy and you’ll get a small suspension performance boost. You’ll definitely be able to clear 37s with proper bump stops.
Seahawkfan
You could just go with 6" wheel spacers and you could skip the 37" and go 40". But you would have find another way around that tree obstacle. :thumb:
FLAVE
To not be a total foreskin shaved samsquanch fucker.... most manual vehicles “require” an extension for the shifter to be welded in place.... morally don’t fucking do it because the amount of suspension lift you would need to “clear” 37’s is cheap enough and nothing more than some jacks,jack stands, and wrenches involved. Tear off your front fenders and it’ll come close to fitting 37’s stock.
2016 Granite Crystal Metallic 2 door Jk
catahoula
I have a 2 door and installed EVO 2" coils, 4 door rear coils with 2" spacers and Rancho 9000's. Running 295's. Did not hit the bump stops and with minor trimming I bet I could run 37's. Do not even see a reason to install a body lift.2 or 4 door.
Benito
Why the heck would you even buy a body lift kit?? Just go to Walmart and buy some hockey pucks, drill some holes in them and stack them as high as you want and install those between the body mounts and the body!
Zevulin
🤣🤣🤣 dirt roads & a mud hole... Man this dude is hardcore!
