Bolt On coilovers: adjusting ride height = alignment?
JK07
Hey guys, tried searching and found a similar question from 2013 with no answer so here it goes...
I have the Evo bolt on coilover kit (awesome) with Evo lower control arms up front. I had the ride height set up when my hard top was on and before installing my winch. I have since installed the winch and I just put on a Trektop NX tonight. I have a bit of rake from the rear to the front that I want to level out. If I lift the front .5" and drop rear .5", am I looking at throwing off my alignment significantly?
Any input or advice is welcomed! Thanks
As it sits now
Alignment? No. Throw some gear in the back and you'll be level again. :thumb:
I would leave it, It doesn't look that bad and if anything will help for when you have people or gear inside!
