jeeeep
I pulled the caliper off, checked the brakes and the only thing I found was odd was that the inner pad had a pretty good scoring mark where the caliper piston is sitting and it looks like it may be moving up and down based on the marks? I pulled the slider pins, cleaned them and reapplied lube. Noise is the same. I’ve got new rear sway bar links to install next and will see if that changes anything. I’m going to check the suspension bushings and fix the upper coil seat next.
View attachment 358196 View attachment 358197
I would seat the coil properly and remove the sway bar links for a test drive.
after watching the video a few times the noise sounds in sync with the up/down motion of the wheel, not rotational.
Is it an optical illusion or are your shocks mounted at an odd angle? have you checked the shock mount ends to see if anything there shows signs of rubbing or loose bolts?
I'd rebuild the caliper but would rule it out as your source of the noise. you would feel that in the braking (caliper slap if it was sticking) or it would feel like it was dragging and would most likely smell the heated brake pad.
