Broken Skyjacker Hydro 7000 Shock...
cozdude
Guy with a Red 2-Door
Hey Cozdude, would you be able to take a picture? I really don't want to "break" anything and not being able to install a simple shock is really annoying me...
It's going to be hard to see that it's bent but it is a little. Just bend it a little at a time
Sent from my iPhone
jeeeep
before you bend anything, try jacking up your jeep as high as you safely can and put some jack stands under the frame, lower the Jeep and the extra droop should allow you to install the shock without bending anything. you may have to remove the tire to get droop needed
cozdude
I did this with my install but the width of the bottom shock is larger than the mount its self. It required a little bending at a time to fit it in a snug as it is now
Sent from my iPhone
fatboy1271
Thanks but as Coz said the shock physically will not fit in the bottom mounting bracket! The bolt "barrel" at the bottom of the shock is wider than the mounting bracket so my choices are bending the bracket or grinding the shock...
jeeeep
ahhh mine were tight but not so much they wouldn't slide in. You're correct, bend just a little at a time - did you bend both sides or just one?
fatboy1271
I started to bend both sides and became uncomfortable with what I was doing; however, I will carry on. It's just pretty frustrating that these are "made to fit my Jeep," yet they don't really.
