jeeeep
.............. I'm curious to see what the measurement is on his exposed shaft length.
My Fox shocks are for 4-6" of lift as per RK.Agreed, but I was comparing his travel to mine as we have the exact same setup and he's saying his shocks are bottoming out. I definitely don't have that issue. Comparing the amount of shock shaft showing I can see he has considerably less. I'm still wondering if he has the correct shocks in the front....
Part Number985-24-012 rear
Part Number985-24-011 front
Did you measure the exposed shaft length (heel Jeeep ) to see what it is on the fronts?
Unless you have a bumper full of lead it should be close to what mine is - 4.5"
maybe it's time you take it into more private quarters like a pm :cheesy::cheesy::cheesy:
I will when I get homeDid you measure the exposed shaft length (heel Jeeep ) to see what it is on the fronts?
Here's a pic that might helpDid you measure the exposed shaft length (heel Jeeep ) to see what it is on the fronts?
Here's a pic that might helpView attachment 235004
I'm running 3" in front as well. Where did u buy shocks? I've heard of them being packaged incorrectly before.View attachment 227533
Sent from my VS985 4G using WAYALIFE mobile app
:thinking: OK...So you're at full bump there. How much of the shock shaft is showing? It looks like the shock is there in the background and the shaft is showing :idontknow:
Forgot to measure... ill do it tomorrow.
Here's your picture. You MAYBE have a half inch more travel that the rubber bump stop may absorb, but it's pretty much at full bump. And if you look at the red arrow here, you can still see your shock shaft exposed in the background. Do measure to be safe, but it looks like your shocks are not bottoming out to me.
Ok so my lift yields almost 4". RK advised me to use the Fox shocks for 4-6" lifts because of the flex. In the back I'm running 4" bumps and it's perfect, we'll was until the Evo Rockstar but I'm gonna install some Synergy upper shock brackets. The front I'm running 3" bumps and shocks bottom out, barely, but i still feel th em hit.I have stock upper fronts. Imean gonna try some 4" up front, or maybe upper extensions. Any suggestions? Thanks
Sorry for late post, yes I did, will post up some pics.Did you install the rear Synergy upper shock brackets on your rig? Can you post some pics? How did that work out for you?
