JayKay
My front passenger canber is -1.0 and apparently it came that way as I only have 9000 miles on it. Even though tolerance is up to -0.6 the dealer said not to worry biut it and that it would cause any tire wear.
Guess the question is....can you see a degree?
A full degree is gonna be visually noticeable, especially with tires that are large in overall diameter. I had a bagged S10 and I checked the alignment after bagging it. It was exactly 1 degree negative camber on the driver's side and 0 on the passenger's side. Ended up having a bent spindle on the driver's side. Just as an example of how much a degree is, I could get 1 finger between the tire and upper ball joint on the driver's side and almost 3 fingers between the ball joint and tire on the passenger's side.
