Thanks guys!
Ok just to get everyone on the same page and how I got to where I am re the DW.
I never had it before the lift, I felt a sliiiiggghhht shimmy going over a bump and that was it.
I then got a 2.5" spacer lift (spacers only, no other bits and pieces)
I installed the spacers and the DW started.
I took them out and no more DW, I then machined them down 20% to get a 2" lift.
DW wobble gone only the slight shimmy as before the lift.
Day 3 and DW came back.
I then got FOX performance 2.0 shocks 1.5"-3.5" lift
I now installed the Cambolts, and it has help nothing.
Last night I checked my steering stabilizer and noticed it was shot, it has 3cm of play in it.
Now I know you say the steering stabilizer has nothing to do with DW, but Im sure it will certainly help getting a new one in my case.
I will be sending my Jeep in for another check, I just dont trust our dealers here in South Africa, and dont feel comfortable leaving it with the "Jeep specialists" either.
I had 255/75R17 GY Wrangler AT tyres on, I took them off and put 245/75R17 GY Wrangler AT tyres on on to see if that will help, and no it never helped.
My DW is most prone when going around a corner over any size bumps and almost any speed above 50km/h (31mph).
This is where I noticed the SS has the most play too, when extending the stabilizer in or out it has play at a certain length, either way.
My steering box, I dont think is worn out, the play I have seems normal reference to other pre 2012 models.
My Jeep is a 2008 JKUR, 76 000km's (47 000 Miles)
I deflated my front tyres down from 2.4 bar to 2.2bar this morning to hopefully dampen the DW a bit. I drove too slow to work this morning to NOT trigger DW and will drive slow back home tonight, DW is just making me change my underwear to much now :cheesy:
EVERYONE with a solid front axle regardless of vehicle make is prone to get death wobble IF you have loose or worn out suspension/steering components. It's just the nature of the beast and even stock vehicles can get it. Running bigger tires and wheels with less back spacing will speed up the wear of your components. Installing a lift and not tightening your bolts to the proper torque spec will lead to death wobble as well.
Ok guys, you win, Im busy uploading the video to youtube re the track bar bushing.
Once again, I really apologize for being so ignorant.
Its must be track bar related, there is quite a lot of play and I see the whole axle moving.
You will see on the video when I upload it and post it here (slow internet in South Africa :doh:
I would like your opinions on it too though when you see it.
And trust me, this time I WILL listen.
I did this before I asked my wife to turn the wheel for me to see any play anywhere.
Again I loosened all the control arms and track bar, shook my Jeep and retorqued the bolts.
Upper 102 NM and lower + Track bar 169 NM, so this should be ok now too.
That would be your issue. As was stated way back in like the second post.
You beauties have cured my DW!!!!
I F*@king LOVE you all!!!!!!! :thumb:
Ok well its 90% cured, I still get a slight shimmy now when going over a bump, but I tested and never experienced the DW!
I will monitor it for the next couple of days while I wait for parts.
What I did for now is put some M24 washes in, stacked to fill the gaps.
The one end I just just couldnt fit a washer in, so there is like 1mm of play and think this is causing the shimmy the other side is rock solid steady.
I swear a oath to listen and believe you guys from now on.
Once again, please forgive my ignorance, but as mentioned by others as well, I was in a panic.
Are the track bar ends rebuildable? I mean, can the bushings be replaced?
Just looked. Energy Suspension, Prothane, Rubicon Express, all sell replacement bushings on eBay for about $30-$35.
Urethane bushings are great if you love that cheap motel bed squeaking sound.
