Dannyboy76
It took me sometime. I had to rock the doors back and forth a couple of times and use WD40. But the does come off the easiest at a 45 degree angle. I also do roll down the windows to get a better grip.
as mentioned, lube will help out a lot. if you still can't get it. open your door, place a floor jack under it, place a cut down piece of 2x4 standing vertically on the jack and place another horizontally on top of it to protect your door and then, raise the jack a bit to put pressure on the door. rotate the door slightly back and forth and then raise the jack just a bit more and repeat as needed. when the door comes, it'll come quickly so be ready for it.
I've never had my doors off yet. I don't know the joy of struggling to remove my doors. Maybe tomorrow or this weekend I'll (try to) pull them off.
I had them ones big I'm scare that some Dbag will crash in to me with out the doors ouch!!
Roll the windows down and just give it a lil lift. Comes right out ok, I don't take off the stock doors cause they're heavy but I do put the trail doors on and off
The more you take them off the easier they are to remove. The first time I did mine to took two of us and some WD40 to pop the passenger side off. Now they are easy to remove.
As for keeping the kids in? Rock doors are the way to go. Gives you that open air feeling but still the security of a door.
I'm scared one of my kids will fall out LOL!!
I figured I'd rather get t-boned with the doors off that way I'm just forced out the other side rather than pinned up against the opposite door..
I was too but I put my daughters car seat in the middle and its a 5 point so its kinda hard for her to undo it. She was also a bit scared sitting on the outside with no doors so by moving her to the middle she loves it now...
Good idea. But my issue is I have 2 kids 1 is in a booster seat now and is kinda clumsy. The other is just getting into a booster seat and doesn't fit in a car seat anymore. Just have to get some half doors I guess.
I'm with you. Last summer mine was in the harness and I did the same as the above poster. Moved her to the middle and all was good. This year, first year in a booster, and I am nervous about it. Just not nearly as secure.
