Plenty of us have done this mod. We'll help you out if needed. :thumb:
The 2 bolts on each side of the frame that go vertical (front most bolts), you will keep those, don't throw them away. Remove rear bumper and factory tow hook. Insert d-ring into frame on each side and put bolts through. Then mark the frame where it will be cut. Pull d-rings back out. Cut frame. You'll notice when you cut the frame, the little cavity on the crossmember will get bigger, grind it out just enough to fit the flag nut that came with the kit to pass through the crossmember hole, you'll have to put it in there later. After it's all cut, paint it black for rust prevention. Then install it all together.
