hbkid22
Be careful about using them at the same time. (Might want to make certain the adhesive remover is not flammable first so you don't go up in a ball of flames.):hot:
Oh no...Wont be doing that at the same time. Using the heat gun to get out as much of the pad/carpet as I can. Then will need to scrap off the leftover chunks. After that I will take the adhesive remover to the remaining glue and scrap off.....sand down the inside and then reseal it with some primer and paint.
