^^^This^^^So you don't have to do one tire at a time?
I wait about a minute between attaching them to the valve stems. I actually only ever get to about the third tire before I need to go check the first one. If you install all 4 at once you'll probably end up going to low trying to check all of them. Yes when setting the set screw in you are setting it to full open.I can relate to that old man back thing.. So you just move around from tire to tire quickly? And when setting up the set screw you are not setting at full on open? Is this correct? Thanks
Thanks, sometimes being cheap is fun...haha.
Thank you! Appreciate the clarification.^^^This^^^
Yes the little button on the tire gauge let's air out but it would take forever trying to air down using it as its really slow.
