Clicking noise ?
Turbo21
To me it sounds like the factory front slip joint boot or clamp contacting the edge of the trans pan. You can try a couple things. Lay under your jeep and look for marks from whatever is hitting. Strap a friend (Overlander) to the underside of your jeep to watch while you drive it. [emoji16] Seriously though I noticed briefly some rotational marks on the front driveline in the video. Look for a clamp end or something that centrifugal force is causing contact somewhere.
The clamps from the slip joint are gone.
If you see any marks on the driveshaft. It’s from when I had it on jack stands (on frame)
Full suspension droop caused the shaft to hit the exhaust. Even with the spacer kit installed. I think next course of action is to pop the driveshaft off and run it around
