Hello My Jeep JKU Wrangler 4 door Auto sport 2010 with 3.8L today showed one code P0202 for a while and after clearing the code it came back instantly when the Jeep switched on i drove it for not more then 1 mile the engine shut off
now it came up with bunch of codes (P0272,P0205,P0204,P0203,P0202,P0201) and engine rough Idle and runs in LIMP mode there is no power it barely can move the Jeep after checking the codes again and again i found if i only switch it on with out cranking the engine there is no code but if i start it it gives the codes (P0272,P0205,P0204,P0203,P0202,P0201)
what do you suggest to start with ?your help is much appreciated.
