MericaMade
This is nice, I like how you left the lip on the fenders and tied it in nicely to the head lights. I would think this would also keep a little more structural integrity.
Finally joined the crew. Tried to grad the line from the fender. View attachment 284887 View attachment 284888
Sent from my VS990 using WAYALIFE mobile app
Is this a hypothetical question? I didn't do anything to mine and they move only ever so slightly at 70mph. May depend on what cuts you do.So what are you guys using to secure the fender better so it doesn't flop around so much?
Are you gluing the fender from underneath are using double stick tape?
I thought about this, at first. After driving it decided it wasn't at all necessary.
We took all inner fenders and supports off on my wife's Jeep and trimmed the outer portion. Only once have we noticed it flapping and it was because a fender clip came loose. Make sure those are all intact and present. Other than that, ours doesn't flap at all that we've noticed.
I’ve noticed mine flip and flop a bit when I get out on open highways. In our lovely LA freeway/gutters, they never move. Maybe it’s because I’m not moving more that 6-7 mph. [emoji849]
Are you gluing the fender from underneath or using double stick tape?
A little of topic, but last night I discovered that Mopar makes a High Clearance fender for the JK... I had no idea... Not as clean as the JL, and expensive, but thought it was cool for someone that wanted a more stock look. And just like the JL they claim 35’s no lift, 37’s with a 2” lift.
I cut the fenders right at the crease line and left about 2 inches on the front curve so they are not flat. I only had to do minor clean up to the inner fender. Around 30 mph I can hear them flop a little. I am going to try and add some double sided gorilla glue tape to secure the underneath of the outer fender to the top on the inner fender. I though some might have run into this issue.
I tried the Loctite brand and it was a waste of money. I'll give this a shot. ThanksI used this to keep my fenders from flapping.
I think it’s a special order DIY thing... I just showed up to the JK party so not sure.
