Stalter08Rubi
It did indeed
Usually a 300 code with no other cylinder codes listed could be fuel related or valves sticking. Did this by chance happen right after you filled up with gas?
Yeah it did
oh, yeah i had that code when I filled up with fuel and there was a lot of water in it. I made it about a block before it started to cut out, run rough and die.
This was right before I was going to leave for Easter Jeep Safari.
I siphoned fuel out of the tank by removing the fill hose at the tank so I could get past that ball security thing and was able to determined I had a lot of water in the tank.
Another member mentioned pulling the fuel line and letting the pump push the fuel out which I finally figured out how to do so I was able to clear any remaining water left in the lines.
Couple of bottles of seafoam later and fresh gas I haven't had any issues since, that's been March of this year lots of miles since.
Have you been driving it since you last filled up or did it do this pretty much right after you filled up
If there was water in the gas at fill up than it shouldn't be my issue to deal with, it should be the company with the shit "premium" gas that I filled up with.
I filled up with ethanol free premium, think that could be the issue ?
Any updates?
Well went by the dealership today and the news I received was not good at all... The technician who was working on it thinks the PCM might be fried, cylinder 2 has a 40% leak and cylinder 5 has a 14% leak and even if the PCM gets replaced it is going to need a head job no matter what so looks like I am going to be about 3200 in the hole on this... :grayno::grayno::grayno:
Dude that sucks. Wonder what caused it so randomly?
no idea but I am screwed, military doesnt quite pay the biggest salary
Ain't that the truth
