The relocation bracket is synergy and is bolted on. Its solid tight no movement and checked for tight The brand new DL and flip is tight and is the sleeves..
Not serious but shit if I just replace both unit bearings the tie rod and drag link, that's pretty much everything that causes these problem
Anyone ever seen the TB itself slightly flex? the bar itself, not the bushings ?
should I try another Track bar I have
check the run out on the unit bearings before replacing them.
unfortunately larger tires cause faster wear on ball joints and unit bearings.
I bought O'Reilly Precision brand unit bearings, 3 year warranty on them and mine failed with about 2 months left on the warranty and they replaced them for free...good deal :thumb:
put a long bar under the tie rod and over the axle - you want the axle side to rest on top the axle so you can pull the tie rod near the joint.
you may need to put your thumb on the TRE where the grease cup is to feel for movement. any movement in the TRE and you'll need to replace it.
