Did the loose Steering improved on 2026 Rubicon?
thunderstrike
I held off purchasing Unlimited Rubicon to replace my 2009 Rubicon 2DR for the improved and recalibrated steering for 2026 model.
If you have 2026, did the steering really get improved? My 2009 has tight steering and my son's 2019 JLU Rubicon the steering wheel was loose, like driving 1960s car. Look forward to hearing from you.
JK and JL Steering is a lot different, especially with the electric pumps on the 2018+ JL/JT. The early model JL's did have the aluminum steering gears that did cause some issues as you have described but have all since been replaced with standard cast steering gears. I haven't heard of any continued issues or complaints.
my 2018 originally had the aluminum box, replaced under recall and it's been good since.
nothing like the 2015 JKU, but good
I took delivery of 2026 Rubicon Unlimited. Very nice, lots of luxury features compared to my 2009 Rubi, BUT steering is loose, not tight like the 2009!
Congrats on the new jeep.
I daily drive a lifted JKU on 37s with PSC hydro assist, and sometimes drive my wife’s stock 2024 JL. I really like the steering in her jeep. Feels tight, responsive and really nimble.
Can’t say one is really better than the other. They’re both great.
That said, I really, really like my hydro assist for running big tires.
Like @jeeeep said, new steering might just take a little getting used to.
Why would you buy a new vehicle with loose steering? You mean the wheel has slop in it or do you just mean the wheel is too easy to turn for your liking?
Dealers love to leave the tire pressure at shipping pressures up into the high 40s. Make sure you’re at least down to 35.
Running cold pressure 34# at 50' outside temp. No improvement.
I used to work at a Jeep dealer up until last year and have never driven a new Jeep that had steering any looser than any other Jeep older than it did. Something is either up with the Jeep’s steering or your perception of what “loose” steering is is different than everyone else’s. The new JLs feel super nice and tight all around, especially the XR Rubicons with the 35s.
So what do you mean by “loose?” Play in the wheel? Super easy to turn? Vibrating? Shaking? Bump steering? I assume it’s still stock and if so I don’t think it’s the tires alone.
Many are telling you to run tire pressures so low that the Jeep will complain incessantly . This makes sense with very large tires (as many here have), but if you still have the factory tires, then either something is off with you perception, or there is a problem with your jeep/tires. With factory tires and the Jeep recommended pressure (e.g. 37) the tracking and steering should be just fine on the road. Somewhat lower pressure (still accepted by the nanny) may be quieter, smooth tiny bumps, and offer better traction, but should not be necessary to steer properly.
I find the steering to need many micro/small adjustments to keep the Jeep within the lane in its proper middle position. If I didn't it tends to move close to left or right lane line-markers. I recall my 2004 TJ and 2009 JK (I currently own) the steering is firm vice 2026 is soft and weave slightly to right or left. It's like 1960's cars' steering, but not that loose.
I did read up about 2026 improvements to come such as tighter steering along with better insulation hard top. Neither have improved.
Also, glove box has no built in light, even though there is a push-rod toggle switch is there on the left side. I think it's just being used to stop the door rattle. I plan to rig up a light for glove compartment. My wife needs it on a long drive.
You bought a brick with wheels it’s what they do. I have a 25 Rubicon it’s taken a bit to get used to the EPS . Here’s what you need maybe.
It took some time to get used to my 2019 2-door Rubicon's steering. I am able to drive it over narrow mountain roads (little margin for error, which could lead to death) without problems. In fact the steering feels great on narrow winding roads. The part which takes getting used to is straight flat roads where the brain feels that adjustments are needed. While feeling that adjustments are being made, I look at the steering wheel and see that the adjustments I make are almost imperceptible, and usually less then half or a quarter of an inch. The human is part of the electronic feedback loop and it does not feel 100% good. After getting used to it, it is no big deal.
It is always possible that your jeep has an actual problem.
