Wunderbar. Anybody mind taking a gander at my wiring diagram and seeing if it passes the smell test?
As far as I can tell, it's the same as the original, but with 2 differences to accommodate for a master locker safety switch and locker indicator on Rubi locker:
Difference 1 - My first relay will be a master locker safety switch that I'll put away from the main switch panel. Instead of the output of that relay going to an accessory, it will go to the power input on the second switch, which will be my rear locker. This way, the locker switch can only receive power when the master locker safety switch is activated.
Difference 2 - My rear locker switch will be a 2 LED switch, with upper dependent and lower independent (
https://otrattw.net/CONTURA-V-REAR-LOCK ... 0-5LR.html). The power for the independent LED will be supplied by fuse 7, with the ground going to the locker indicator (not the locker actuator). When the locker engages, it closes the indicator switch on the diff, and my independent LED gets it's ground. This way, the independent LED is on when the locker is engaged, and off when it's not, regardless of if the switch is on or off.
Does anything here seem wrong? From what I've read (and again, I'm a n00b), this seems like it should work, but wanted to run it by the collective wisdom here.
