Do I have a dropped pitman arm?
NM2012CherryJK
Hey guys I'm trying see if I have a dropped pitman arm. The previous owner installed a lift with nothing but drop brackets. So this past month I have been correcting all that. Installed drag link flip with track bar relocation bracket. Adjustable control arms and new tierod and draglink and axle shafts. I'm not sure if it had a dropped pitman arm however. It drives fine didn't even put the steering stabilizer back on. Any help would be great thanks.
ImageUploadedByWAYALIFE1437005773.786371.jpgImageUploadedByWAYALIFE1437005787.984603.jpgImageUploadedByWAYALIFE1437005802.464871.jpgImageUploadedByWAYALIFE1437005815.195227.jpg
Okay thanks I thought so. Should I switch it back to stock now? Would it hurt if I leave it on for a while. I just got the alignment done. Thanks.
Try hitting a few good bumps on the right and see if you still think it drives fine. I'd think you may feel some bumpsteer as your DL and track bar will move at 2 different axis's. Rule of thumb is they should be parallel. Id pick up a stock pitman arm.
If you do have one then your steering will be out of whack and not in line like it should. If you can see your drag link and track bar are not parallel which they should
Okay will do. Will that correct the steering then? Will I have to get another alignment done? Thanks.
Man that looks crazy, did they flipped the drag link and put a drop pitman arm on?
The drop pitman arm was done by the previous owner when they put the lift on. They had a drop bracket for the track bar on the frame side. I'm trying to correct everything I just got done installing the drag link flip and getting rid of the drop bracket on the frame side and noticed that it looked like it had a dropped pitman arm. But as I didn't install the lift wasn't sure.
Okay cool thanks. Do you know where I could pick one up that's not crazy expensive? Thanks.
I think crown has them, but you can look/ask around. In the mean time you should check the torque on your dropped arm. Ask me how I know, I'm slowly re doing mine also. (bought used jk w lift)
Okay cool thanks. Yea the person that had it before really cheeped out on it but drop brackets for everything. If it's not one thing it's another but I think once I get the pitman arm back to stock I should be good for the front just need a drive shaft.
man this thread is now making me question mine. Can anyone post a picture of what a stock pitman arm looks like so i can get a visual on the difference?
make sure you tie your steering wheel to keep it from moving or you'll throw the clock spring out of whack....
put straps on it on both sides to keep it from moving- I used straps from each side of the steering wheel out the window and strapped to my rock rails to keep it from turning.
make sure you tie your steering wheel to keep it from moving or you'll through the clock spring out of whack....
okay cool thanks for the tip.
