Tylersilverjku
I have a similar issue that occurred when travelling on corrugated roads and through water above a certain depth. Turned out when the lift was put in, the shop disconnected a clip that holds that ABS sensor wire still, and didn't put it back together when they finished. The result was the ABS harness rubbed against the moving wheel intermittently and wore the wires bare, shorting out with the right vibration or when bridging with water View attachment 201406
That might be something to look for thank you! Did you just rewire it, replace it?
