iRonin
What is your caster set at? Also the unlimited usually has caster built into it.
Struggling to find my result sheet at the moment but the target I gave the shop was 5 degrees as given to me by Northridge. Digital on the ball joint is giving me lil closer to 6 (5.88) give or take so I can def afford to gain more if it means nudging that coil back that last little bit. I think I'm finally putting this all together correctly in my head, Eddie mentioned Unlimited comes spec'd for 6, so if I told the shop 5 it would be rotated too far forward, which makes sense. Hopefully shortening the uppers will be enough
