Yeah the new trackbar bracket should have a hole in it where you can relocate the steering stabilizer.  The only other thing you'll have to so is rotate the tie rod mount so the stabilizer sits above the tie rod.  Also yes the kit should have included a bracket which attaches to the drivers side coil perch to raise that side as well.  This is where a right angle drill comes in handy as you have drill a hole here and is pretty much impossible with a regular drill unless you want to remove the brake assemble and dust shield.
If you talking about that hole(the one without the bolt in it), I don't understand how that would work then.  I'm not saying your wrong, I'm saying I don't understand and I need clarification.  Do I just stick the bolt through the stabilizer and then through the front of the bracket and that will hold it there? :thinking:
The old set up I had, was a Synergy bracket that bolted onto the spot where the trackbar went (stock) and it flipped the stabilizer up.  It had two tabs that the stabilizer fit into; the stock location also had two tabs it went between thus my assumption was, that is how it was supposed to be.
The bolts I had were not long enough to put that Synergy bracket on the new Evo bracket (why would it, I mean it makes sense that it wouldn't, I understand that)
My thought was in the winter over my break time, I was going to order some longer bolts to fit both brackets on, and then weld the Synergy bracket on the Evo bracket and then I could flip the stabilizer back upwards like I had it.
What are your thoughts?  Do I need that Synergy steering stabilizer bracket or does the Evo drag-link flip kit bracket already come equipped with it and I'm just not understanding something? :thinking:
Currently the steering stabilizer is in the stock location as you can see and I do not want to keep it there long.  I have damaged too many of those things in that spot and want to get it out of there as soon as I can.  Additionally, what are everyone's thoughts on a steering stabilizer anyways?  For a vehicle such as mine with mild modifications and its still a daily driver, is a stabilizer worth having and investing in?
