I would suggest going with the longer RS9000XL Shocks for a 4" kit even though you are getting 3" coils. The only gotcha to this suggestion is you may need new brake lines as I don't think the brackets lower the stock ones enough (not certain though).
RS9993311 Front and RS999332 Rear.
This will help with more down-travel. When you switch to the 37s you will likely loose some up travel unless you significantly trim the fenders. What Bumpstop kit selection are you getting? The 35 or 37"?
