EVO Front Bolt On Coil overs with Dynatrac axle
Cadima
Hey guys, the EVO Front bolt on coil overs require you to install brackets on the lower shock mounts to move the mounting points outwards a bit. My question is do I just discard those if I have a Dynatrac PR axle on front? The PR already moved the mounting points outward and they have a bit different shock mount than the factory axle. From pics I've seen it looks like the kings bolt right onto the dynatrac lower shock mounts. Anyone confirm? thx
That is correct you can just bolt them directly to the PR44 shock mount.
