OverlanderJK
Resident Smartass
Tennessee ain’t much warmer. lolMaking a Tennessee run to see the Kin Folk.
Virginia is!
Pit stop!
Virginia is!
Pit stop!
It’s was more than three times as warm at when we stopped!Tennessee ain’t much warmer. lol
Those Bucees toilet seats...It’s was more than three times as warm at when we stopped!![]()
I see why you love red and yellow jeeps now…Not sure there is anything we did not buy…
This.Diesel oil changes. Brand new oil is black almost immediately. Normal.
I didn't know you drink. Awesome!All finished! Now it’s time to drink![]()
that's a lot of sediment.I finished up on F-Cracker today.
I changed the fuel filter. It’s actually really easy to do.
After you remove the skid plate there is a small valve that lets you ‘drain’ the filter before you pull it off. Well, that’s cool but even after draining it, when I screwed off the filter/filter cap there was still a couple of cups of diesel in it- so I’m not sure that’s really very effective.
The old filter was pretty dirty.
Quite a bit of sediment- good thing there’s a filter!
New filters from Mopar are hard to get so I use these.
The fuel filter housing cap uses a 28mm socket!? Not 27mm like the oil filter.
Not having a 28mm I had to make a run to town. The third stop had them.
Also replaced wipers. These basic ones were $14. Some of the more Gucci versions were up to $31.99!
I’ll stick to the cheap ones even if I gotta change more often.
Since I was on a roll I topped off the diffs with lube.
All finished! Now it’s time to drinkand eat a big steak.
Drinking after the 4th stop I thought the first three before were brewery stops lolI finished up on F-Cracker today.
I believe the petcock on the fuel filter is the water separator. Only drains whatever water it has collected not the fuel in the filter.I finished up on F-Cracker today.
Yup, it’s the water separatorI believe the petcock on the fuel filter is the water separator. Only drains whatever water it has collected not the fuel in the filter.
If my memory is serving me well that is…
