Flat Nasty/Moonlight Memorial Day weekend
Chris1015
It was a good experience for sure. Already ordered a new diff cover and lube lockers. Drove home and stopped about 8-10 times every 50 miles to pump gear oil back in. Had a real consistent leak in the rear. Busted the rubber/plastic boot on my drive shaft. Not sure yet what I can do with that.
Chris1015
Flat Nasty though I will say is unreal. Definitely a place to try out for just about anyone. They had some insane rock trails to crawl around on.
BaddestCross
A hammer, grinder, and RTV will fix that leak. Which boot broke? The slip joint or the rpezza boot? The slip joint can be replaced or zip tied together. The rpezza going out will cause you to lose all the grease in the joint and your driveshaft will freeze. You can replace it but it will break again... Time for a new driveshaft if that's the case.
TrainWreck618
It was the slip joint boot. We hammered the cover back flat and told him to grind the cover down so it doesn’t happen again.
