Ford Super Duty Axle Swap
Mybadjk
Yes and no. The 05+ has 35 spline outer stubs but require a TON more work and will also be 8x170 bolt pattern. The 04 and down have 30 spline outer stubs, can built a lot faster and easier, and will be 8x6.5 bolt pattern. If someone wants me to build them a set I recommend going with the 04 down axles and installing be Dynatrac free spin kit. This does a few things.
1) Eliminates the unit bearing
2) Keeps the stock ABS tooth count so you can continue to use a ProCal if you want
3) Gives you a 35 spline outer
Yeah the cast on the new ones are a bitch. Found a guy that sells them with them cut off for a great price. You have to change the outer stub for the dynatrac free spin kit? I didn’t know they made a kit. I knew Currie did.
Nvm Currie is unit bearing. Saw the dynatrac kit is 1800
Exodus 4x4
Yep. So when someone wants me to build them, I basically charge them my cost on all the parts, plus labor. If a guy has to source all the parts at retail and then build it himself, then it becomes unrealistic a real quick. Of corse that’s just my opinion though.
metalic
Ford went 8x170 in 99 when they introduced the super duty. Does the dynatrac kit convert it?
Sent from my SM-G930V using WAYALIFE mobile app
fiend
I haven’t looked at the specs on Dynatracs website for every iteration of this product, but the couple I did look at say the product is for stock wheels. I take that to mean 8x170mm, not 8x6.5”.
