noroad
Has any one put one of these under there jk!
http://www.currieenterprises.com/cestore/productsRE.aspx?id=3416
Randy (the guy with the silver JKU that has done all the JKX's) had currie axles and kept breaking them. After the first time I'm pretty sure they told him he was too hard on his jeep and that they wouldn't warranty them anymore. There is a reason why he runs dynatrac's now.
What are the weak points on the Currie axles (where did they break)? I'm assuming it's not something that could be reinforced to avoid breaking?
I don't have any experience with these axles. RidgeRunner has a pair of Currie Rock Jocks he is waiting to slap on. And although they aren't this specific model, he will at least be able to give you some feedback regarding Currie axles soon enough.
As you can see, the mounts are already in place, nothing left to weld on. However, the cones extend roughly an or so more than a stock housing which means it will likely require different drive shafts. I have a set of JE Reel 1350's on order and will be doing the entire install next week.If I recall Randy's were a semi float, Currie now has a full float which should remove some of the issues related to the Rock Jok.
Sorry I was not aware that he had already upgraded to the full float rear axle and was still having issues. I just wish could afford a set of Dynatracs. A friend of mine just got a set, 60 front and 80 rear just under 20 grand delivered to Yellowknife.
Most of the breaks I have seen were on the rear axle - mainly broken shafts, one of which happened on JKX 2011. After his 2nd break, Currie wouldn't warranty them anymore and said he was playing too hard. Not exactly something I'd want to hear after dropping so much coin for something that was supposed to be a lot stronger. I'm not sure the exact amount but, he's also broken multiple ring and pinions.
Still sounds like in going with a pr44
:thumb: You wont be disappointed!
