Truck scale would be perfect. More people do it than you would think. Or swing out to my work one afternoon and we can run you across the scale at the pit.
You know, I might just take you up on that one my friend. Let's discuss later.
Oh and when I say truck scales, I mean private scales like at a truck stop. I wouldn't go Cruze through an inspection station. HP might not like that.
Right? That would be so funny. The story would go something like "So there I was driving through the truck scales despite several warnings and lights. When I got my read out, I just continued onward and then there were more lights and this time sirens behind me. I guess they just wanted to make sure I got home okay but then....."
you might try your local dump, the local dump here has scales and I've gone and weighed my Jeep there before
That is a very good idea. Thank you.
12 ton seems like overkill to me. :thinking: The price point also seems very high. I was also looking at the Safe Jack kits like this basic kit for $179.
http://safejacks.com/collections/bottle-jack-accessories/products/basic-bottle-jack-kit
Is there a reason why a 6 ton jack would not be more than sufficient?
You don't need to lift the entire weight of the vehicle...just a portion of it
I have a 2.5 ton jack and I can tell you it does not lift 2.5 tons at all, barely raises a corner of my vehicle. So I suspect that the rating is not always accurate. I also note that when using said "2.5 ton jack" it takes a lot of work. The higher rated jacks are leveraged for easier work. So when I am pumping a 12 ton jack, it is easier per pump than a 2.5 ton or a 6 ton jack. The relative weight ratings between the two almost dictate a much easier stroke. Also, there is greater material strength in general, which is important when the jack may be fully extended. I am no expert, but I remember my physics classes and hydraulics for the sake of discussion here.
As for the basic Safe Jack Kit, that is the same price as the $188 12 ton jack that I provided in a previous post. But I see that the Safe Jack gives you more, such as a 3 inch extension, flat jack pad, canvas bag and bottle screw adapter, a very nice kit. In looking around, I like the jack bases. But the problem for me, and maybe it is personal, these are Chinese made. Check the manual it says "Printed in China".
