High steer with ultimate dana 60.
jeeper52
LOSER
The knuckles on the UD60 front axle should work fine. They are flat top knuckles and the passenger side knuckle already has a high steer arm. You'd need to have the driver side knuckle drilled and tapped for a high steer arm, and have a new set of blank high steer arms drilled to fit both knuckles.
So where could i send the knuckles out to get the drivers side drilled and get both fitted with new high steer arms?
highoctane
You'd likely have to have a competent offroad shop do this for you. That I do not know. I know that it's best to mill the flat top of the knuckle, to ensure that it is true my flat, then drill the holes.
