Sheaffadelic
This is freakin beautiful
Threw the fridge in this morning, wish I would have last night so I had some cold drinks with me
I currently have it set to 40...is that good?
There is a secret offset you can set on the fridge to adjust its temp reading. The manual does not mention it, I found it somewhere in another thread. I think you can offset the display 10 degrees each way from the actual temperature. I think I offset mine about 8 degrees cooler. The actual temp inside was warmer than the fridge thought it was. To get to that menu you hold one or two of the buttons down for ten seconds. I can't remember right now. I set mine to 30*F and it does pretty good without freezing things up solid. Maybe on a cold night that might be a bit much.
Everybody loves taco meat
