Regolith
Bumper and tire carrier have been holding up fine. I did have one squeak/chirp that was occurring whenever I would hit rough roads or off-road. It was being caused by the ubolt of the latch rubbing on part of the piece that the latch latches to. I pulled the ubolt off and bent it at a bit steeper angle to fix the issue.
As far as advice goes, I would recommend that you install the whole bumper and carrier before you paint or powder coat and make sure everything fits as it should including drilling all holes and installing Rotopax, then pull back apart and paint. My install went pretty smooth except for setting up the rotopax. I had to elongate the holes in the big JCR bracket that the rotopax mounts install on to get the 2 gallon rotopax cans to fit properly within the tire carrier tubing.
Hey I just wanted to follow up and say thanks for the advice. I installed the JCR Adventure Carrier today. It went on without much problem. Just wanted to say thanks.
