Hutchinson wheels
2011jk
FYI....never had a issue in Ca running non DOT beadlocks in 20 years on the street and have been pulled over many times. Personally I will only run Allied.
Mikead40
Exactly - 98+% of cops either don't know or don't care about DOT compliance... At least that's what I gather from the general consensus on this board where lots of people are running ATX slabs and never been hassled by the Po' . Theoretically the only concern would be if you were in an accident... And people got hurt... And it got extensively investigated...and it was determined that a failed lock on a beadlock caused the accident... And you get the point...DOT compliance or not, beadlocks, if we'll maintained won't be a big deal. The reason I went with BAD wheels is because they have the benefits of beadlocks without the maintenance and...worst case scenario.. Are still considered dot compliant.
Irishcoffee
Hope Below details
Hutchinson Rock Monster Installation Manual: https://www.hutchinsoninc.com/wp-content/uploads/MP0189_RockMonsterManual_REV-H.pdf
Specification sheets for Rock Monsters for Jeep:
WA-0594 (!HUb Centric for JK/JL!)
https://www.hutchinsoninc.com/wp-content/uploads/2020/04/spec_0594.pdf
Rim Size: 17 X 8.5
Rim Contour: TRA J (ISO)
Offset: -0.26 in [-6.6 mm]
Mounting Pattern: 5 Holes on Ø5 in [127.0 mm] B.C.D.
Hub Bore: Ø2.816 in [71.5 mm]
Load Rating: 2300 lb @ 60 psi [1043.3 kg @ 4.14 bar]
Weight: 35.6 lb [16.1 kg]
WA-0398
https://www.hutchinsoninc.com/wp-content/uploads/2020/04/spec_0398.pdf
Rim Size: 15 X 8
Offset: -0.925 in [-23.5 mm]
Mounting Pattern: 5 Holes on Ø4.5 in [114.3 mm] B.C.D.
Hub Bore: Ø2.895 in [73.5 mm]
Load Rating: 2300 lb @ 65 psi [1043.3 kg @ 4.48 bar]
Weight: 26 lb [11.8 kg]
WA-0566
https://www.hutchinsoninc.com/wp-content/uploads/2020/04/spec_0566.pdf
Rim Size: 17 X 8.5
Mounting Pattern: 5 Holes on Ø5.5 in [139.7 mm] B.C.D.
Hub Bore: Ø4.22 in [107.2 mm]
Weight: 34.3 lb [15.6 kg]
Tires recommended for Hutchison Beadlocks:
Rock Monster Parts Numbers: https://www.hutchinsoninc.com/wp-content/uploads/2020/11/RM_PartNumbers_2020_2.pdf
Seahawkfan
Hope Below details are helping.
Hutchinson Catalogues:
Rim Size: 17 X 8.5
WA-0398
Rim Size: 15 X 8
WA-0566
Rim Size: 17 X 8.5
Better late than never. You do realize this is from back in 2014? :thumb:
