shortyokc
i recently did the drag link flip kit and track bar relocation kit from synergy and since then i have noted a bit of flighty and wandering steering that i did not have before. i dont know if this in normal and was always there but never noticed it because of the lack of the flip kit and track bar kit. i have removed all bolts/hardware and ck for wear and found nothing, ck multiple times for loose bolts, marked them and none of them have backed off, rotated or paint rubbed off to indicate a waling bolt. the track bar and the drag link are parallel as far as i can tell, all new joints on new parts and jeep has 16,000 miles. i have the aev correction brackets on the last lower hole and ck my pinion angle at 89.5 degrees off the front pads on the diff and also removed the driveline and ck on the flange to be sure. the tow is right at 1/8 in. iv ran tire pressures from 40 psi down to 28 psi on 35x12.5x20 fuel mt tires (yes i know i want 17's). the axle is centered with a synergy track bar, i have went through every part and found no issues or loose/worn components. i installed these parts and tempted to loose the drag link flip and track bar relocation bracket to see if my issue goes away. i also have the fox ats and have played with the adjustment and still have flight steering.
