Jeep build 3.0....ish
Sk8convict
Drive shafts in and on. Anyone ever run into this issue?
It was hitting the 1350.
Problem solved with the sawsall
My old ram hoses I got from redneck ram were too short and I didn't order a 1.25 clamp for my tierod. So... I grinded the clamp down, it bit and did fine so far with wheels off the ground but.... I doubt it will work.. 1.25 clamp ordered....
Just noticed the front brake lines as we were cycling the steering and bleeding the ram. Ugg any ideas? I know I need to get new/straight? Ones...
Fluid going in the diffs and bleeding the brakes. Then I think I can pull it out of the garage and go wobbling down my street
So I can align it........ several times. [emoji15]
Benito
I ran into that issue as well with the flange.
I carefully bent back the tubing on the brake lines just enough so I could have some clearance, but I don't know if you could bend them enough to clear the coilovers.
Mine had fluid in them, i stuck my finger in the fill hole and didn't feel anything, so I started to put some in but it started to come out after like 5 pumps. I need to change it, it's already been +1000 miles.
Sk8convict
Oh yeah. And no wobbling. No vibes, except good ones.
I do have a weird clicking sound in my shifter when I touch the brake pedal in park. Like a loud switch? Any ideas?
