Jeep is leaning to passenger side
I am not sure if mine was that bad. I finally got mine adjusted so it would sit level. You may have to add spacers if adjusting sway bar links doesn't help.
Angry Aussie
Thank you everyone for your input. I don't have adjustable sway bar links they are just standard. It's leaning hard in the front as well. I'll try adjusting the track bar and see if it helps. If not I'll get it on a lift this week and check springs and everything. Thanks again everyone.
suicideking
I had a friend with an old VW Bug and it lean backward. So he put two 60 lb bags of concrete in the trunk to level it out. :D
