Help me out here guys, what are the pros & cons on the two different set ups on coilovers? I will use the 2 door stretch for an example.
1st is the Vengence set up with the coilovers inside the frame at an angle. EVO 12" stretch.
2nd is a pic I found of the Synergy 8" stretch. The coilovers are mounted outside the frame more verticle like the front would be.
If you had enough room to run the coilovers outside the frame, then could you use the same bracket as the front from EVO? And would the flex,articulation be the same as the other set up?
