2nd.gunman
So I took the Jeep to the dealership and they scanned for a code and they did not find one. They did the transmission update and they said the issue has been fixed. I have had the jeep back for two days and I am not having any of the previous issues, but actually a new one...kind of.
Since the transmission flash update when in first gear i get to around 1500-2000rpm and then the jeep kicks forward and changes to the 2nd gear. In 2nd gear it gets to about 2000-2500rpm and then kicks into 3rd. After 3rd the kicking stops when shifting gears. The vehicle does feel a little sluggish from what it was, but it could just me be re acclimating myself.
I called the dealer and they said after flashing for the tranny update the vehicle has to re learn your driving habits and over the next 2 weeks it will adjust itself and the kicking should stop. If it does not stop, I can call up and have it looked at again. Is this an actual thing or are they pulling my chain? I've never heard of a transmission needing to adjust to driving habits, but then again the new wranglers have so much controlled by electronics I could be wrong.
Any advice?
Almost all modern automatics constantly adjust their programming to provide the smoothest operation possible. This is to account for component wear and driving style. I.e. Throttle position vs load. You quite often find that if a car has be thrashed its whole life then sold to someone who baby's it, it will shift really harsh for awhile until it adjusts.
ECMs do it as well in Australia the ford falcon 4.0 6cyl is notorious for running perfectly until you get a flat battery and it loses its memory, forgets how worn out it is and will barely idle. But after a few weeks of driving is back to normal
