JKU feels like it floats
A.J.
Got it thx
If the lift has been on awhile and it used to drive good, you may just have some worn parts. It doesn't take much movement especially in the track bar to make it drive poorly. You said you don't have bump steer or wobble, just floaty feeling. Have someone saw the steering wheel back and forth sharply while you watch the front end parts and look for movement. Check the track bar bolts and make sure they are tight. Make sure it's all good and tight before you just throw new parts at it. Check out Eddies DIY alignment write up and go through the steps so you know where your at. If you are still having trouble post a couple pics of the front end from the center with everything visible. Happy to help but can't just guess. To see is to know.
