Bingobelle
Thanks for info.
The duff: yes, it is going solid I´m concerned about. Especially at high speed on the highway.
The problem with rubbing: is that only if the swaybar is disconected? Or can the jeep flex as much with the swaybar connected and still rubb?
Will use stock shocks for now. Only the spacers will be done. Will later buy a more correct lift with all parts but that will have to wait for maybee two years or something like that. Just want the 33" tire to fit for now.
What do you mean with the 3" range on a 2012?
My jeep is a saharah 2012 4 doors with penta engine and automatic.
Dont get this, if I follow with a bumpstop high as the spacer, how can i lose uptravel? the spacer move the coil and axle down from the stock bumpstop so i should gain uptravel with stock bumpstop. With a higher bumpstop similar to the coilspcer, should they not take each other out so to say? sorry for bad technical english.
thanks for you time!
