TRAUMAhead
Teraflex 1.5" leveling kit (spacers), chopped flares, 35s.
![8874698822_7cf35e9db9_b.jpg](http://farm4.staticflickr.com/3829/8874698822_7cf35e9db9_b.jpg)
![8874087043_a6318c6836_b.jpg](http://farm3.staticflickr.com/2814/8874087043_a6318c6836_b.jpg)
![8874091215_4b44e36bed_b.jpg](http://farm9.staticflickr.com/8417/8874091215_4b44e36bed_b.jpg)
Who's running spacers and who has performance leveling kit? Curious how much a winch will make the spacer leveling kit drop...
The EVO 1.5” HD Leveling Kit is exactly what’s needed to give your JK some added lift to clear larger tires and to compensate for added equipment like a front bumper and winch. The supplied EVO 2” front coil springs offer more front spring rate then the soft stock front coil springs and the rear coil spacers give the rear the added boost needed to compensate for added rear equipment without adding spring rate to the already payload rated stock rear springs.
The EVO 1.5” HD leveling kit equalizes the springs and gives just the added boost you need while leveling your JK.
The Kit includes:
2” Lift Front coil springs
¾” Lift Rear coil spacers
I'm running a EVO leveling kit. Springs up front and spacers in the rear.
How are you liking the ride Robar? Looks good!
Ill add my True Blue Pearl to the mix. TF leveling kit, 285/70R17 BFGs and 17" Fuel Trophy wheels, Stock springs.
I'm still running Rubi shocks, but the ride is fine. I want to go to some Blistein shocks and that should help the ride lot.How are you liking the ride Robar? Looks good!
Sorry I was wrong I have just the spacer kit with the optional 1.5" spacers.
May be dumb question... b5ut...
You added 1.5" spacers on top your leveling kit?
