bruggymonster
So I looked on North Ridge and the evo enforcer is almost $1300 less than it is on the actual evo website. Is this normal? Or am I missing something?
Probably looking at a different kit.
I figured it out, on the evo website, it comes with the king shocks and the drag link flip kit.. newbie question again.. I know the shocks are just better than stock but not necessary right? and I don't know what the drag link flip kit is for? :doh:
You can run Rancho or bilstein shocks to fit your budget. The drag link flip kit centers your axle, corrects your roll center, corrects steering geometry, and puts your steering stabilizer in a better position. Worth the money imo because you re-use your factory track bar and no need to purchase an adjustable one.
Another quick question.. On the North Ridge website, it shows three different options for shocks, Bilstien 5100, Evo Spec 2.0, and Evo Spec 2.5 w/ res.. Probably a noob question but what are the differences between the shocks? I'm assuming ride quality? :hmm:
Oh and what is the "w/ res"?
bruggymonster;481479 Oh and what is the "w/ res"?[/QUOTE said:Means it has a reservoir attached to the shock.
good, better, best.
the reservoir helps going on washboard roads. and i think those have an adjuster knob. i'm not sure on that.
good, better, best.
So with the 3" EVO Enforcer, 2.5 w/ res King shocks, and drag link flips, is there anything else I need to get/ change? (drive shaft, etc.)
Front ds yes, rear is fine, but move your evap skid. You'll shred up your boot. Check your front shocks at full droop to see how close the body is to the frame. *May need relo brackets. *Might be able to run evo rockstsrs. Other than that, sounds good
Newbie question... Could you dumb that down a little, what's a boot? and how do you relocate the brackets? and what do the evo rockstars do?
