How the fuck did trophy truck come up? If you want a trophy truck ride, buy a fucking trophy truck, not a brick.
Firstly I've seen two parts dealers in Ontario(that will ship) that have installed EVO stuff. Also the And I can think of a few others in Alberta. If you want you can PM me for those sites. Since they're not vendor preferred. And I thought in Quebec you had to run winter tires? And max on road was a 35"? Or has that been changed/is this purely a toy? Also I have a 2.5" lift and definitely have enough for 35s and maybe even 37s if I really tried to make them fit
Thats a big no-no. Dealers can you only install Mopar performance parts and can get the big nasty stick slapped at them from chrysler. Can they do it still? Yes but its against their dealer agreement.
You can even run 37's on a stock JKU Rubicon suspension if you'd like. Just depends on how you're using your rig and what kind of off road you do with it.
(Here, stock JKUR on BFGoodRich 37's : https://m.youtube.com/watch?v=pOm6cyKWZpU)
I personally would like the gain of articulation a 4" lift would provide my rig. But that's me.
Running 37" tires on a factory suspension is dumb. Just me
To get a "trophy truck like ride", you need to go coilovers. And 4" of lift on a 2dr is just silly.
4" on a 2 door is stupid. Way to much lift. If you put 3" coils on a 2 door you would prob net 4" or more depending on how light or heavy your rig is.
Stupid is a bit strong. I did it and it was fine, for the most part. Makes the 2dr real bouncy and if I was to do it again on a 2dr I'd go 3".
If you're trying to go "trophy truck", you definitely don't want coils, much less 4" coils. Go coilovers.
Dude, 4" is way to much, check out my build thread, on my 2 door I netted around 4" from my 3" EVo plush rides and it makes my 35s looks small, even when i get to 37s there will be plenty of room. I can get max articulation with the trim fender and its rides great on and off road. EVO springs are one of the softer rides and it flexes great but if you want to blast across the desert like a trophy truck you never will with coil springs, i think my jeep rides outstanding and on those washboard roads it gets pretty treacherous above 40. Granted i could run a better shock but it wont make that much of a difference unless you make the jump to coil overs. I dont know a lot about all the items you listed but but ive heard blistens arent to bad and the fox shocks i used to run were ok, thought they were pretty stiff. but if you get much over 3in eventually your going to need drive shafts, few adjustable control arms, drag link flip, raised track bar brackets, extended brake lines if you want to flex it out, or else the jeep will drive like shit and you can forget about driving fast anywhere.
Check out OverlanderJK's profile. He's running 2.5" RK springs with 37" tires. And from what I see on this forum, he wheels the shit out of his 2 door. Remember this, a 2.5" lift usually will give you over 3" of lift. That's more than enough for your "articulation ".
Will do, but he's been kind of a dick since this thread started... x_x
Do you just copy and paste the same thread over and over and then change a few words?
Who Overlander? No, I think you're mistaken. You must be thinking of someone else.
See for yourself - maybe it's just me... Anyways
Dont want to speak for my man WJCO, but pretty sure he was bleeding with sarcasm in his comment
