Spudcannons
Not to get too off topic but I love your rig Olram30.
I would think having the long arm kit that you have very few limitations. I have the enforcer pro but haven't actually maxed out the flex yet. This picture is right after trimming the fenders and is 35" off the ground.
Could the misalignment joints reduce bind and the better geometry allow for longer shocks for more flex? I know the lower angle of the long arms helps a lot with holes and ledges where a higher angle would try to force the wheel down Thanks to OmanJeep for the excellent graphic of the axle travel.
I took your link out, no need to send our members to another forum. So if I were to put long arms on my jeep, would it flex more? These are about the longest shocks a person can put on a standard coil lift.
So your saying a good long arm doesn't flex any better than short arms ?
It's like measuring from your asshole and saying you have a 12" dick
Sorry about the link I'm too used too citing sources :cheesy:
So with the shocks that I have they max out at ~12" so any more travel would need coil-over shocks? Is this where a long arm would allow more travel because the wheels stay centered giving more clearance vs short arms which would rub the sheet metal and since there is nothing to fall out they can keep going?
Here's another diagram of what you're talking about. I guess eventually the long arm would droop lower than short arms would, but that is well beyond the limits of the shocks, even coilovers. View attachment 138824
I hope there isn't any diagram of this![]()
Damn come on I was in the process of making it lol.
Sweet JK build!
That's a nice looking rig! Is that disconnected? Will a ramp cycle the suspension as well as a lift?
Also a bit off topic, what welder did you both use for the rock sliders? I am about to weld them on but I am not sure if my miller 140 will penetrate enough for the welds to hold up to large rock hits.
