BattleAx09
I’m planning to re-gear my 2013 JK soon and I had some questions. My current setup is 3.21 gears with 33-inch tires and a manual transmission. I would like to re-gear to 4.56 and add an Eaton E-locker in the rear at the same time. Are there any particular brands of gears that I should avoid? I’m currently looking at G2 or Yukon master install kits. From their websites, it looks like G2 carries a much longer warranty on their parts so I'm leaning toward them. Also, does a master install kit include the new front carrier that I need since I have 3.21 gears right now? I’m going to have a shop do the install; I’ve gotten one quote for $900 for labor…is that reasonable? Last, my plan is to connect the E-locker to a switch panel in the cab. I’m currently looking into the Painless Trail Rocker overhead switches. From what I can tell I need to separately purchase a length of wire to get from the rear locker to the front of the Jeep to connect to the relays in the engine compartment. Is there some wiring specifically made for this? How should it be routed? This is a huge and expensive project and I want to make sure everything is done right the first time. Thanks for the help!
