Evo or Currie. They both use Johnny joints on both ends. Evo can be adjusted on the jeep without removing.
Unless currie changed, they can not be adjusted on the jeep.
Correct, just the evo can.
They can? How? I run them and seems you have to drop the adjustable end out, spin the end then tighten the collar. :idontknow:
Wait, evo can't be adjusted while on the jeep?
I always thought you loosen the pinch bolt, turn the collar, then tighten the pinch bolt back up.
Loose pinch bolt, adjust collar in and out. It's adjustable on jeep
Have you ever tried?
Yeah, when I put my lift on and set my caster. Are yours hard to adjust?
No. Luckily for me I had two good friends help with my install. So mine were adjusted for me.
I purchased the currie ONLY because I could get all 4 to match and didn't see where EVO made all 4 "short" arms or I'd have bought theirs. I drive myself crazy with petty things like that. Well no instructions came with and it may be obvious but which end is frame end and axle end?
