That was a shitload of work...I say forget the back seats and bolt in two fridges...one dedicated to beer only...
I think you should make one really long half door though.
Did you happen to build an access point to switch the lever from spool in, free spool, and spool out?
I like it! It’s definitely unique as mentioned. A ton of work for sure. Knowing what you know now, would you do it again?
I dig it. Looks like an island vehicle.
Looks amazing! You really drew the winch into the grill. Crazy skills!
Looks good.
Crazy how stubby the front bumper is. That sure come out clean for as much work as it had to take.
Thanks. Pushed radiator back 1.5”, cut 5.75” off frame and moved a bunch of stuff. Lots of test fitting.
Yes and No. No because I wouldn't build the same thing twice. But I don't regret doing it. Sure it was a heck of a lot of work, cutting metal and wires not really knowing what I was getting into, but having the confidence that I can make it work. I have a Fuck it Cut it, now I got to fix it mentality.
...but having the confidence that I can make it work. I have a Fuck it Cut it, now I got to fix it mentality.
I mentioned about disabling the voice control because I don’t like hitting it by accident. I took the steering wheel apart and took the button assembly apart. On the button pad I cut off the Voice and phone button rubber tit that makes contact with the button inside.
View attachment 323071View attachment 323072
Not my thing, but I do appreciate the quality of the work and the challenge of the task.
