scull20
You can try Davy's Jeeps, summit racing may split them, jegs, quadratec, eBay, junkyard. Or just order two and save yourself the time of finding one.
I'll give them a shot, thanks!
Just came across a pic of your rig with a 35" on the stock Rubi wheels on your tailgate.
Did you do anything special to make the spare fit? Assuming you have the OEM carrier still.
I haven't spent too much time on mine, but it looks like I need to chop down the third brake light and maybe shorten the isolators a tad?
Could you shed some light on this?
My warn M8000 pulled 2 other keeps plus myself up the ledge at Uwharrie and also pulled me sideways up a hill...so far, I couldn't be happier with my purchase. Also, pulled a few bushes around the house.
On the factory wheel w a 35x12.50 tire, i have good firm contact with the tire carrier isolators. No spacer needed. Its held up well so far, and the toyo is a pretty heavy tire (~78lbs). Some people have been able to cram the spare on w the 3rd brk lite still intact but i didnt like it. I cut it off at the base and used plate/lite relocation setup by Rockhard. Works great.
I would try taking it out and putting a little blue lock tight on it and put it back in. Id bet that would hold it.Those of you who have put 90* zerks in your evo LCAs...whats the trick? Mine keep ending up facing the wrong direction...
Now that you said that I believe your right. I would still think if you put lock tight on it and got it as close to possible to tight where you want it it should be fine. I could be wrong though.I think he is saying that the way the hole is threaded, the zerk is inaccessible, not that it is spinning. Is that the case Medix?
How hard is it to wire up a front e-locker in a "sport" jk? Im no electrician, but id like to tackle the full axle install in my garage...
No i give up on a used one. Just gonna buy a new one...just need to figure out which one lol. Either way, im either going to have a factory rubi locker, or an eaton e lockerDid you finally find yourself a D44??
What about if i went dynatrac? Same thing or no?Not sure if its year specific but heres what ya need. http://m.quadratec.com/products/product.php?pid=52446+111
When the time comes, im sure dynatrac or ORE can answer thatThats a good question that I can not help you with. I bet there probably is a way but everyone I know with a pr44 has a air locker.
Thats good to know. I havent researched it much yet since i dont know which route ill be going, but its good to know eitherway, its probably just a wiring harness...After a quick google search, looks like if you get an Eaton e-locker it comes with a wiring harness.
